The Dremel 8220 variable-speed cordless rotary tool offers the highest performance of all Dremel cordless rotary tools. Released Date: June 22, 2012
6 Questions View all
There's a burning smell coming of from my device?
My Dremel has started to emit a burning smell shortly after a few minutes of work. It occasionally emits some smoke. How can I fix this?
Add a comment
1 Answer
Chosen Solution
The burning smell coming from your device might be related to different reasons. First, make sure that the carbon brushes are not worn out since that might cause the burning smell. If they are worn out, they might need replacing. Also, make sure that there's not dust trapped in the tool. If there is, you can get rid of it by spraying compressed air into the openings of the device. Lastly, make sure that the motor is not burnt out. If it is, that might be causing the burning smell. Replace the motor.
Add a comment
Add your answer
Shailing Santiago will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 34
All Time: 365
