How to replace sensor 2 on 1998 Honda accord
I have a diagnostic code ( bank 1, sensor 2) heater circuit malfunction. The vehicle is a 1998 Honda accord. 4 cylinder, 2.3l engine . I'd like to know how to replace sensor.
Comments:
I have a 3.0 Honda accord 1998 two door code reader says po 135 code engine light is on just replaced just replaced oxygen sensors and light still on
by
Add a comment
1 Answer
Chosen Solution
maesars622 i m a bit confused by your question. It sounds like you are referring to Honda's OBD P0141 code. If so, than there is a problem with the heater element circuit of the heated oxygen sensor.Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check the fuse and connectors.
Bank 1 sensor 2 would be the sensor after the catalytic converter
For the repair, check this videoNot the best but it should work
Score 4
Add a comment
Add your answer
masears622 will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 189
All Time: 3,520
