The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Is it possible to test a mic with a multimeter?
I need to test several mics for the iPhone 1st Generation. Sometimes they come damaged, and the only way to test them is soldering them to the System Connector. Is there any way to test a mic with a multimeter?
Score 1
Add a comment
1 Answer
Chosen Solution
If you want, you can cut the end off of a 3.5mm audio cable, and attatch the 2 wires to the mic, and plug that into the microphone/audio-in jack of a computer and see if you can hear anything.
Score 1
1 Comment:
I will try and let you know...thank you!
by
Add a comment
Add your answer
Flavio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,301
