The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3501 Questions View all
Why is my iPhone not charging?
Here's my problem:
I connected a 3.5mm (audio) cable to my iPhone 5s while it was playing music and it did not turn off the loudspeaker. Tried it with iPhone earbuds as well and the Headphone jack isn't working with that either (music keeps playing over loudspeaker).
Later that day the iPhone battery died (seemed to have emptied quite fast too) and when I tried charging it later nothing happened (I'm sure the charging cable works).
As Headphone jack and Lightning connector are the same part (dock connector), I tried replacing that part but it was to no avail; still not charging/turning on.
When I first plugged it in after replacing the part I did hear a ticking noise coming out of the loudspeaker but it does not do that anymore now.
Left it at the charger for over an hour, just to be sure.
Any idea what it could be? I'm fine with opening up the iPhone and replacing other parts.
Add a comment
Chosen Solution
For future reference:
Apparently something on the logic board is causing the battery to drain quickly. This killed my current battery. So in order to fix this, the logic board has to be replaced or fixed and the battery has to be replaced.
I am going to replace the battery myself (€13) and let an iPhone repair company fix the logic board (€120).
This way I can keep my original logic board and my Touch ID will keep working as well (Touch ID only works with the logic board it came with).
Add a comment
Most Helpful Answer
if you already change the charge flex check very carefully the conector in the mainboard looking for any damage and try whit another flex.
Score 1
Comments:
Thanks for your comment, I'll try taking a look at the lightning connector socket to see if it is damaged.
by
No visible damage to the lightning socket (here's a picture of it http://i.imgur.com/pCjbdUc.jpg )
Already tried replacing the flex cable (as part of the dock connector) so don't think doing that again will help
by
Really!!!!!!! look at the picture you send, there is a lot of damage!!!!!
Look remove the foam cover on the socket and check, i see burn damage in bot the charger socket and the battery.
http://i.imgur.com/WXc0Sr0.jpg
by
I'll take another look at it this evening. If it is the lightning/battery socket that's damaged, do I need to replace the entire logic board to fix it?
by
unfortunately yes
by
Show 1 more comment
Add a comment
Add your answer
Bram will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 262
