Replace optical drive with SSD?
What is the speed difference with the optical drive vs HD SATA connections?
This series uses a PATA optical drive which I/O speed is 133 Mb/s. Your HD SATA port is SATA II (3.0 Gb/s).
I wouldn't recommend switching out the optical drive for a SSD. Between the very slow I/O speed you'll also encounter issues finding a SATA I (1.5 Gb/s) SSD that will work effectively here.
A better direction here is to switch out your current HD for a SSHD drive like the Seagate Desktop SSHD. That way you gain the speed of the SSD but the storage depth of a standard HD.
The other direction you could go here is putting in a SSD replacing your current HD. Given the age of this system I do caution people from investing too much here. If you find you're only web surfing then a 128 GB or 256 GB (better) SSD might still make sense.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 110
1 Comment
Is this your system: iMac 20" 2.0 GHz Core 2 Duo
by Dan
