The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Question Closed
How could I fix my sunken USB input?
Could anyone tell me is that a tool that could fix my sunken USB? Or how could I make a tool by myself to fix this? Thanks a lot!
My computer's sunken USB is like this...
Update (04/03/2016)
如图,欢迎推荐各种可能可行的板手之类的东西,谢谢TAT ps这张照片就是去天才吧修时拍的…天才吧说他们只能换不能fix,换要两千多,于是我决定自己找工具修或者找五金店修,所以来这边求助,谢谢啦
As shown, please recommend a variety of possible practical things like wrench, thanks
PS This photograph is to repair a genius when it shot ... only for the Genius Bar that they can not fix, change to more than two thousand, so I decided or find your own repair tool to repair hardware store, so come here for help, thank you
1 Comment
你可以把连接器的好照片,所以我们可以看到被损坏。它粘贴到编辑模式下你的问题。
Can you take a good photograph of the connector so we can see what is damaged. Paste it into your question in edit mode.
by
Add a comment
Chosen Solution
Google "duck billed pliers", get a pair and fix it. Put a piece of heavy electrical tape on the top of the dent to help from marring the finish.
Score 5
1 Comment:
Thank u so much! This is really helpful! I just bought one "duck billed plier" from Taobao Store… and I'll try to fix that like what you've told me. Thanks again.;)
by
Add a comment
The part which is damaged is called the "top case."
It usually comes from Apple complete with a keyboard and battery and is pretty expensive. But you have the possibility to try and repair it using pliers. And if not successful (it can easily break), you can then replace it. If you order it bare, it will not cost you much, but will be a very big pain to replace, specially to remove and transfer the battery.
Before attempting to repair, you have to take your I/O board out in order not to break it. This is the guide that shows you what that I/O is and how to remove it from your top case. And in case it is damaged and the USB not working anymore, you can order it and replace it as well.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 124
