Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Home Button cooper contacts damaged
I have a 3GS and my home button is not working properly, so i opened the phone and i saw the j3 connectors, the ones in the dock connector part were the problem. One of them was in a good shape, what i mean it was gold colored, the other one not so much so i grabbed my screw driver and try to remove this silver kinda thing but i made it worse as you can see in the picture, is something i can do to repair, cuz i know is not making contact, that's why my home button is not working property thanks
Can i solder it??
Score 1
Add a comment
1 Answer
Chosen Solution
any chance of a photo or a better explanation of where you have damaged? is it the gold prongs on bottom of home button or on the dock connector. there are quite a few gold and silver things!
Score 1
Comments:
i posted the photo, and is in the dock connector
by
you should be able to buy just that top piece of flex on the dock connector. it can be found quite cheaply, in fact they sell it here either separately ( you need the dock flex, not antenna flex) or you can buy the entire dock connector if you think it's a bit too much hassle to fiddle about with little pieces.
I would also look at the underside of your home button and just check the 2 gold prongs that make connection to dock flex aren't flattened. it is more likely these that were the problem in the first place than the connector you removed
by
Can i fix just the little copper piece like solder??
by
i don't think so. you could give it a try, you've nothing to lose iPhone 3GS Dock Connector if you click on this image it'll enlarge to show what your part should look like
by
Add a comment
Add your answer
Rafael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,639
