Why are my tires locked up?
I have a craftsman yt 3000, 21 hp mower and have this problem. It will not roll, the tires seem to be locked up so I jacked it up and the tires spin freely, one in one direction the other in the other direction. Any idea what I've got going on?
Add a comment
1 Answer
Chosen Solution
It's very likely that it's related to the transmission or the drive belt, not the tires.
Here's some more info:
http://www.mytractorforum.com/14-craftsm...
  • Check the clutch/brake travel. Are you sure you don't have the parking brake set when you are checking belt tension?
  • Do you have the little finger thingy sticking out of the rear plate that allows you to push by hand. Is that out or in?
  • It's possible that the pivot for the tensioner has rusted up, if it's been sitting. Getting under and eyeballing it should tell you.
Score 1
Comments:
the drive belt looks to be in place, why would the tires spin in opposite directions?
by
Because differential gear boxes : https://www.youtube.com/watch?v=SOgoejxz... which are universally present on vehicles that have more than one drive wheel.
by
Add a comment
Add your answer
jimm will be eternally grateful.
Past 24 Hours: 25
Past 7 Days: 163
Past 30 Days: 643
All Time: 1,148
