Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
202 Questions View all
Put iMac late 2014 5K LCD on iMac late 2015 5K?
Hello everybody
i am new here
i just broke the LCD of my new Imac 27 late 2015 5K :(
i am unable to use the warranty
so my question is :
the imac 5k late 2014 is using LM270QQ1 SDA2 for LCD
the imac 5k late 2015 is using LM270QQ1 SDB1 for LCD
i know the main difference is late 2015 is using P3 color gamut
but i would like to know if theses two are compatible ?
in other words :
Can i put an Imac 5k late 2014 LCD on my Imac 5k late 2015 ?
does they have the same cables ?
i would like to do that because the LCD from 2014 is less expensive...
Thanks for your answer
Score 1
Add a comment
1 Answer
Chosen Solution
Apple lists them as the same part number - 661-00200 iMac 27" LCD Panel and Glass Assembly, Late 2014 / Mid 2015. Review the compatibility section to be sure your system is listed.
Score 3
Comments:
Mine is LATE 2015 not mid 2015
by
Sorry don't have an answer here for the newer model. Have you tried asking Apple for the bench rate for repairing this system? It might be worth it.
by
no, but i assume it would be over 500 euros, so too expensive
i know both lcd are 5k , both are using the same cables
i am just scare about the P3 color gamut thing
thanks anyway
by
It might not be that high, can't hurt to call or visit an Apple Store to ask :-)
by
you are right, i will call
by
Show 3 more comments
Add a comment
Add your answer
Fanny Augier will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 1,377
