Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
515 Questions View all
How do I fix a broken audio-out jack?
I accidentally knocked a line that was plugged into my audio-out jack. Now, nothing works in that jack unless I fiddle with it for a very long time, and sometimes it never works.
My Mac speakers work, but I can't plug anything into the audio-out jack to use large speakers.
Add a comment
Chosen Solution
Sounds like you broke the tip off inside the receptacle. If so you can open it up and slightly pull out the center bracket of the back of the port and remove the tip.
Score 2
Comments:
Add a comment
Hi there, if the suggestions that you've already received doesn't work then just simply replace that I/O board for your machine, I don't think that they cost that much.
Score 1
Add a comment
Add your answer
slicesofamerica will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,882
