The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1562 Questions View all
iPhone 5c Microphone doesn't work
A little while ago the microphone on my iPhone stopped working. There must be two mics, because phone calls work, but calls on speaker phone, Siri, etc don't work.
I'm going to be replacing my screen anyways, so I thought it might be a good opportunity to replace the microphone. But I can't find parts or a guide for such on here. Is it included in another set of parts or something? What can I do?
Score 1
Add a comment
Android Fix Kits
A new screen or battery is one kit away.
Shop Now
Android Fix Kits
Shop Now
Most Helpful Answer
That mic is located on the front facing camera cable. It's pretty easy to change that cable as part of the screen replacement.
Score 1
Add a comment
Rich is correct. most likely needs replaced but the earpiece mesh can get also fairly blocked up which also includes a hole for that mic. if you remove the screen and that part then take a look at behind it, hold screen up to the light and you should see light pass through it. if not then scrape the mesh from the inside and outside with a fine pin etc to allow more sound to pass through.
Score 1
Add a comment
Add your answer
Evan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 194
