Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1286 Questions View all
Can I replace the power plug receptacle on the side?
The power cord does not seem to connect well with power source plug. Is this a common complaint and can it be replaced by owner?
Add a comment
1 Answer
Chosen Solution
Yes the DC-IN port can be replaced. BUT The most common problem with this machine is a spreading outer ring on the AC adapter plug. This can be squeezed back together to make it tight again. The fast, but poor way is to squeeze it with a pair of pliers testing for tightness and then doing it again. The professional way is to wrap some wire around it and twist the wire till it's closed enough for a good fit.
Score 2
Comments:
Add a comment
Add your answer
craig Liming will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 711
