Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
How do I make ASD work on a 2011 MacBook Pro?
I've managed to get a copy of ASD3S148 but I'm struggling to find any information on what to do next (eg: how best to install it on an external hard drive and run it safely).
Apologies if this is a stupid question. Any help appreciated!!
The reason I'm doing this: My fan is permanently on full while my RPM is reading 0 and my temperatures are normal. AHT says 4MOT/4/40000002: Exhaust-0 issue, which means 'faulty fan' but the above info makes me think a broken/missing sensor could be the problem (which is feasible - I cleaned the fan and changed the RAM so may done something by mistake).
Would like to run ASD to find out exactly which, if any, sensors are faulty. Thanks.
3 Comments
Now have copy of ASD but no idea how to install/run it safely. Google not giving much away. Any help appreciated.
by
where did you get ASD 3S148 for MacBook Pro Late 2011 15"
by
ASD is Apples internal diagnostics tool. It does not offer much more than the built-in diagnostics (just more glitzy to show the customer). When you visit the Apple genius when he plugs in his HD that is what you see. A graphical breakdown of the same core diagnostic engine.
Apple now uses a networked version of the tool so you'll need to have a Apple ID which gives you permission to access Apples servers which have it.
How about creating a fresh question will all of your details. I'm sure we can help you without spending hours trying to find something that won't offer much help over what you already have any ways.
by
Add a comment
1 Answer
Chosen Solution
Sadly, I don't find ASD very helpful when I'm working on a fan or temp issue. I find TG Pro is a better tool.
In this case I can tell you your fan or the connection to the logic board has a problem. Within the fan is a tachometer which appears not to be reporting properly. First inspect the connector area on the logic board make sure in the process of disconnecting the fan you didn't damage one of the small components as well as the connector its self. If it all looks good replace the fan that should fix it.
Score 2
Add a comment
Add your answer
Harry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,419
