Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1347 Questions View all
How to fix iTunes error 4013?
I've already replaced the battery and the Charging port with the sound port. I'm still getting this error and want to know what exacttly is broken. I really think it's the Logicboard because i've tried quite everything whithout luck. I hope anyone with the same error can help me out. Also if i try to restart the iphone it causes a respring loop. It's not Jailbroken and on iOS 9.2. When its powering on it goes off after a few seconds and starts again. If you know whats causing this let me know. Thanks in advance.
Score 4
Add a comment
Most Helpful Answer
Error 4013 is corrupt NAND chip in my experience. If under warranty--have it swapped, otherwise out if warranty replacement is your best bet
Score 7
Comments:
change the c.c port first dosent wok change NAND :)
by
Add a comment
Hi Max
Knowing that you already replace the battery, the charging port, having in mind you have updated iTunes and try few different original cables (with all USB ports on your PC/Laptop empty) there is one more think you can try:
This error could be caused by the lack of space for the update to install on your device. Try going to Settings>General> Usage – Make up some room in your memory.
Keep me posted
Score 1
Comments:
I've already tried a few cables and also a virtual machine and a macintosh machine. For the space: I can't power the device on. It starts and power off after a couple of seconds.
by
You may need to change the battery again and make sure the battery is known good.
by
Add a comment
I have the same problem , I saw some posts on You -Tube. if you replaced your screen, the home button is not recognising your phone. Apple has updated their software want you to use the original screen display.
Add a comment
i have same problem i fix Nand flash by third party tools like iPboxv2, you need hardware propositional to remove nand flash from pcb first
Add a comment
Add your answer
Max Mustermann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 113
All Time: 9,062
