Screen black, touch screen works though
So I got this iPhone 5C thinking it was going to be an easy screen replacement... Before I replaced the screen it would vibrate multiple times when on charge. I read that this was due to a display not being plugged in.
I've replace the screen. Touch screen work but I can't see a thing.
I've notice on the board there is a pin missing but I think that's to do with the touch screen?
2 Comments
i have problem too but the connector on the board does not appear to be damaged in any way
by sam guveya
sam make sure the connector is seated flat when you install, if the connector is bent in the middle or sides it willl have issues, also check the pins on the flex cable.
by Oscar C
