This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
Why is my battery life draining so fast?
I’m using my Kindle to read for only a few hours a day and the battery life is always low. Why is this happening? Is something wrong with my battery or Kindle?
Score 8
1 Comment
My Kindle is only 7months old but the battery is running low after a single day reading. Really baffled and disappointed. Is this normal ?
by
Add a comment
Chosen Solution
That is a common problem that happens. Good question!
You may not be using the optimum settings on your device. It is recommended that you set the Brightness to 10 and turn on Airplane Mode when the Wi-Fi is not being used. While this will extend the battery life, it is also dependent on how long you use the device for each day.
If you are still experiencing battery life problems, you may indeed have a faulty battery. In this case, you may need to replace your battery.
Score 8
3 Comments:
Please tell me where I can get a new battery.
by
Where can I buy the new battery?
by
Add a comment
It happened to me also after firmware update in March 2016. It is a bug in the version 5.7.2.1 - something with indexing books. Fixed with manual download a install version 5.7.3.
Score 1
Add a comment
Add your answer
Micah Smart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 74,505
