The Black and Decker is a cordless household drill that can be found by the serial no. LDX 120C
4 Questions View all
Why isn't the chuck able to tighten?
When i turn the head of the drill to loosen the head nothing is moving, what do i do?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The problem you are facing is because of the planet gear inside the chuck. the gear might be loose, or some the components may be broken and need to be replaced.
Follow our guide (haven't completed the guide yet) that provides a step by step process on how to do so.
Check out our Troubleshooting
for more help.
Add a comment
Most Helpful Answer
My drill had the screw that holds the chuck to the shaft come loose, and it bound up inside so the chuck wouldn't turn. I took it out, and it worked fine after that. The chuck hasn't fallen out either, must be glued on.
Score 1
Add a comment
Add your answer
jeffrey zakka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 90
