How to Disassemble JBL Pulse 2
How to disassemble JBL Pulse 2 or is there any other way non damaging to fix the dent in my speaker??
take the rubers out from the sides and you will find out 4 screws under that cap you will find another 4 take the rubers out and in front of the bottons unscrew the cap and unplug the collor sensor and the bottons pull the cover out . YOU ARE INSIDE THE JBL PULSE 2. I also have upload a video in youtube with some helpfull images. https://youtu.be/wmQrxOqkEx8
how to remove the rubber on the sides can you please show some pictures or videos tnx
Awful video. Just a guy showing his disassembled pulse 2 from all angles to some $@$*!& music.
Assembly of the speaker includes a lot of 'glue' so- so taking one apart is a pretty difficult process (if you expect to put it back together).
Go slowly, use a small screwdriver, knife, scraper - and a heat gun That is your best chance of having something you can put back together.
My JBL Pulse 2 has a broken micro usb charger port! I can see the problem! One of the little prongs inside has broken off. Is there any way to fix it without having to replace it?
i saw some technic in youtube just check it out tnx
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 13,319
