How can I fix this
I dropped my iPhone5s earlier, and now it has a straight big black line on the left side, and won't stop glitching and works then doesn't, someone please help me. Suggest things I can do?
Chloe,
Looks like the drop fractured the LCD or damaged the solders on the back of the LCD. A screen replacement will fix it.
Regards
Holger
I agree with Chloe that a new screen will most likely fix your problem.
If a new screen does not fix the glitching then that will tell you that the logic board has an issue.
Sometimes after a hard drop a cold solder joint can form behind the Touch IC which would cause glitching like you describe.
Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
1 Comment
Glass cracked or not cracked? Also is the frame bent?
by Ben
