No signal with HDMI
I bought a PS3 slim 250 GB jailbroken and It worked fine on Samsung LED. but I shifted to a new LED and it isn't working. It shows no signal, I changed HDMI wire but no use. Sometimes it shows the screen after reset video setting but after entering in PS menu it blanked out on NO SIGNAL. PLease guyz help me. After sometime I tried again and it worked and I played for almost half hour then I want to play some other game, When I press PS button to QUit the game, then the NO SIGNAL sign pop up and since them it is not picking singal also video reset is not working.... please guyz update me with a solution.
For informing about the solution.
jazzibtheking44@yahoo.com.. that's my E-mail.
Hi, Have you proved that the problem is not the TV? You say you changed the HDMI cable, did you try a different HDMI port on the TV? Can you try another TV or even a monitor with a HDMI connection to see if it is the PS3 or the new TV that is the problem?
by jayeff
Hey man
i have a similar issue as well and haven't been able to fix it yet.
My HDMI is not feeding out any video output though. Only getting output through AV.
Every other thing on PS3 works perfectly fine.
A good place to start checking if you have any electronic experience is to open up the mobo and look for any blown resistors/fuses or any other visible sign of damage. If you notice any charring or damage, its a good idea to post back here with your findings cause there are some users here who have access to a schematic or two that maybe able to identify the damaged component and guide you further for replacement.
If you don't have the experience, then a local PS3 mech is your best bet.
He will charge you a pretty penny, but from my experience, will more than likely be able to fix the problem.
by Captain Monkey
