Searching? Calls failing? Doesnt recognize sim card?
Dropped the phone and the screen went out, and also bent the phone/frame a bit. Replaced the screen and it came back on seemingly working perfect, but now all calls fail, its always searching and when i remove the sim it doesnt change at all, doe not seem to recognize that a sim is being inserted or removed. Tried restarting adn resetting network settings, airplane mode, soft reset and battery pull. Please help! Thank you!
Anyone? Im assuming a component fell off in the drop, does someone has a circuit board picture/map that could show me where i could check and maybe try to solder?
by Austin Harris
Well the whole frame was bent, possibly when the board flexed and when you it got bent back, it damaged the logic board internally with the circuit(s) inside causing it to have these issues.
Do you still have an IMEI number listed under settings > general > about iPhone? If not then you have a hardware issue. (Don't post your IMEI number though)
by Ben
