2.3L 4cyl or 3.0L V6, 6th Generation
305 Questions View all
Why can't I roll down the window on the driver's side?
2002 Honda Accord
I can't roll down my window on the driver's side. What can cause this to happen?
Score 1
Comments:
Is it electric or manuel?
by
Is it the front or rear window? If it's the rear (and electric) window, have you made sure you didn't accidentally click the "child lock" switch?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The driver's side relay usually goes first,it should be inside the door panel, new is likely expensive, go to an auto recycling yard and ask for one, it's used but cheaper,you'll recognize it inside the panel after you have it in your hand, should be the problem..
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,184
