Why can't I roll down the window on the driver's side?
2002 Honda Accord
I can't roll down my window on the driver's side. What can cause this to happen?
2002 Honda Accord
The driver's side relay usually goes first,it should be inside the door panel, new is likely expensive, go to an auto recycling yard and ask for one, it's used but cheaper,you'll recognize it inside the panel after you have it in your hand, should be the problem..
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,230
2 Comments
Is it electric or manuel?
by mayer
Is it the front or rear window? If it's the rear (and electric) window, have you made sure you didn't accidentally click the "child lock" switch?
by Miroslav Djuric
