Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
How do I install the os after I replace my HDD?
Hi, I am about to replace my HDD with a new one and of course I want to reinstall Snow Leopard... Just to be sure, what's the exact procedure I must follow? (how will the computer boot up since the hdd will be blank?)
Add a comment
Chosen Solution
You can boot from the system installation disk by inserting the disk and restarting holding down the "C" key. You will need to go to the second page pull down menu to Utilities -> Disk Utility and format the drive. You can then install the system. If you need to access your old hard drive for the data let me know and i can give you instructions for how to do that.
Score 1
5 Comments:
I already use 'time machine' so I suppose transferring my data to the new disk won't be a problem..
Thanks a lot for the instructions!
by
Just start up from your system disk and go to "restore from time machine".
by
my MacBook pro will no boot up with Snow Leopard while holding the C key.
by
minnow . Please start a new question as I have no idea of what machine you have nor the history of it. Also this is an eight year old question and - just do it!
by
Add a comment
If you have a little HDD storage case (very cheap to buy) you can connect you new HDD to your current rig then run Disk Utility format and then go to 'restore'. There you can drag your old HDD icon to the "FROM" box and the icon for your new HDD to the "TO" box and hit enter. About 4 hours later if you are using a USB cable you will have a copy of your old HDD. All you need do them is follow the instructions to switch HDD's. If your old one is still working Ok you can put it in the storage case and use it for backup.
Add a comment
Add your answer
thalord will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,441
