Lenovo business laptop introduced in April 2011. The X220 replaces the ThinkPad X201. The X220 has since been replaced by the X230. Main improvements are : 1366x768 IPS screen available, 2nd generation Intel Core CPUs, new Trackpoint, new Ultrabase, SATA III
14 Questions View all
Why does my fan make a high pitched noise?
My computer is making a high pitched noise when running and when in sleep mode. How do I fix this?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
The high pitched noise may be due to your fans needing to be cleaned, try blowing air forwards and backwards through the fan. Another option is to shut your computer off and let it cool down. If noise continues you may need to take the computer apart to do more cleaning of the fans.
Score 1
Add a comment
Most Helpful Answer
You can start by cleaning the fan first by blowing air through it forward and backward . If this doesnt help then take the laptop apart and do a more through cleaning of the fan put a touch or lithium grease in the bearing . If this doesn't help you will need to replace the fan
Score 4
Add a comment
Make sure of exactly where the noise is coming from before you spend any money. It could also be the hard drive. See this video: https://support.lenovo.com/us/en/videos/...
Score 4
Add a comment
Add your answer
Emily Heffernan will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 107
Past 30 Days: 405
All Time: 4,568
