Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3188 Questions View all
iPhone 5 Tapping / touching by itself
iPhone 5 started acting like someone is touching. For example: started opening apps by itself, typing, and moving the cursor all around.
What can be a problem? LCD or connector? o maybe other things :/
I think the screen is replaced (it's a gift 4 me)....
Name it Michael Jackson.
Add a comment
Chosen Solution
Problem you are facing is the digitizer connection from the screen into the logic board. Fixing this issue will require the removal of the screen by either a repair shop or yourself (with caution). The connection may have come loose or doesn't have a solid connection so removing and re-attaching may fix the issue but in my experience you will most likely have to replace the entire screen.
Score 2
Add a comment
The most likely cause will be the screen but if after replacing it you are still having issues it could be a problem with a Touch IC chip on the board. This can be reballed or replaced to fix the issue.
Score 2
Add a comment
Add your answer
nikab will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 87
