The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
17 Questions View all
Question Closed
How do I separate the housing set after removing the screws?
I removed the screws but the housing set is stuck on the ergonomic grip. I tried prying it open with a plastic tool, but it started to damage the external case. Where should I pry open the Dremel 4000 to avoid this?
Add a comment
1 Answer
Chosen Solution
The Dremel 4000's cushioned grip which can make it a challenge to pry apart the casing. The key is to first remove the housing cap which will expose the hard plastic threads of the exoskeleton, then use your prying tool to start a wedge there. This troubleshooting page may have additional useful information.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 443
