Where is the radiator fan sensor
rosecare1, the engine coolant temperature ( ECT) sensor is mounted in the coolant stream. The power control module (PCM) applies 5 volts to the ECT sensor signal circuit. The sensor is a thermistor which changes internal resistance as temperature changes. Your ECT sensor ( you did not give us an exact model and year) is most likely located in the water outlet housing, adjacent to where the upper radiator hose connects to the engine.
Check this video as well
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 24
All Time: 1,654
1 Comment
where is this fan sensor on 1998 cavalier
by mwharris56
