Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Likelihood of ultraonic cleaner + isopropanol fixing water damage?
If I have a water damaged iPhone 6 which isn't turning on due to water damage, what is the likelihood that putting it in an ultrasonic cleaner with 99.9% isopropanol will fix it?
Out of ten, roughly, how many would it fix?
And what's the recommended amount of time to leave it in the Ultra sonic cleaner for?
Thanks
Score 2
Add a comment
1 Answer
Most Helpful Answer
Hi john to answer your question is the ultrasonic cleaner and I am talking the $100 versions for me it works 7 out of 10 times and I set mine on for about 5 to ten minutes but I use electronic cleaning solution and my mixture is about 4% cleaner and 96% distilled water but with the alcohol solution I am going to be honest and say I don't know. The stuff I use is industrial so you have to contact the company to get it but here is the link http://www.echemproducts.com/ultrasonic-... now for the ultrasonic cleaner this is what I use and your getting a better deal than I did for $76 instead of a $100 https://www.pce-instruments.com/us/index.... Here is the cleaning solution you can easily get your hands on http://www.all-spec.com/products/635-022...
Score 5
7 Comments:
Please add a brand name and link to ultrasonic and cleaner solution.
by
I will try to find a not so industrial cleaning solution to for you guys and I am truly grateful mayer that with that comment you helped me improve the way I answer questions.
by
@meepfish1 Answering questions well is a learning process and you get better at it over time. You're doing fine ;-)
by
Thanks @meepfish1 eepfish1! I have this Ultrasonic Cleaner - http://www.amazon.co.uk/Floureon-Ultraso...
Does it seem alright, do you think? And would you assume that 10 minutes is probably a good amount of time for the alcohol method?
Have you had any experience using alcohol?
by
STOP - using alcohol in an ultrasonic would not be a good idea. Think of an open bowl of petrol or gasoline being vibrated and emitting fumes around an electrical ignition source. https://www.youtube.com/watch?v=iWtohHwN...
by
Show 2 more comments
Add a comment
Add your answer
John Taylor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 284
