The Verizon Ellipsis Jetpack MHS800L is a 4G LTE mobile WiFi hot-spot designed to be pocket sized and portable.
4 Questions View all
Why won't my device's battery charge when it is plugged in?
My device is plugged into a wall outlet via the charger. The charging cable doesn't appear to be damaged and everything else looks fine visually.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Mr Betts,
I would assume that the internal battery is damaged or old, and wont hold a charge. If the battery is in state of needing replaced then your device may not even turn on.
Add a comment
Add your answer
William Betts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 122
