Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
125 Questions View all
iMac > 2012 AIRPORT? is ad hoc apple MPCIE port?
Hi all,
I've a 1 million $$$ question:
Is the airport mpcie apple proprietary port?
From some images found on google, the airport (at least for imac from 2012) is not a standard mpcie port but a smaller one.
There are some converter?
My aim (if possible) is to connect a egpu through mpcie.
thanks all
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I'm not sure I follow your logic here. If you want to push another screen with its own GPU you don't need to go this route.
Let's start with the AirPort card it's a mini PCIe interface which is a standard Broadcom BCM4331 part. No, you can't use it for anything else as the hardware & software of the system is expecting the AirPort card for this connection.
So, to gain a second GPU here you'll need an external Thunderbolt case to hold a standard PCI graphics card. Here's an example using a MacBook Pro: Using an Thunderbolt Video Card with a MacBook Pro using a iMac is not any different.
Score 3
Comments:
Mmmmh.
http://www.hwtools.net/Adapter/PE4L%20V2...
As you can see there are mpcie to pcie converter that run under Windows. I already have it and it works with my old laptop
Airport device (from 2012 i think)
http://www.thebookyard.com/images/IM21AP...
This is not an mpcie device or at least has not the interface of an mpcie device
Infact:
http://www.tonymacx86.com/attachments/ne...
Is an AIPORT -> mpcie converter
But from the picture seems that is just a proprietary connector rewired.
So the complete answer was:
"Under bootcamp (that maybe can support more devices), can be connected any sort of mpcie device to the airport port?
There is an adaptor/converter for the airport port?"
I already have akitio on my main iMac.
I own a second iMac made of spare parts and i just want to investigate more on the capabilities of the logic board just for eperiments.
by
Nope! The AirPort card is a mini PCI express (mini PCIe) not mini PCI which is different! The PCI standards group created a family of different interfaces which does make conversion and fitting devices confusing!
In any case the root issue still applies here, the system & AirPort port interface is not designed to support a GPU interface you'll need to use an external case.
by
Add a comment
Add your answer
ilpala will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 107
