The Cowon iAudio U2 is a compact device that boasts stylish and elegant looks, an FM radio, line-in and built-in mic recording, and as much as 2GB of memory. It measures just 2.9 by 1 by 0.7 inches and weighs just 1.2 ounces.
3 Questions View all
Am I able to reset this device?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi,
There is a reset button (in the reset hole, see image, left picture below). Use a paperclip or something similar that fits. Press gently, you will 'feel' it operate. Hold for a few seconds then release.
If that doesn't work, try re-installing the firmware. Here is a link to the User Manual, scroll to p.67 to see how to install it. this will probably erase your data so if you can do a back up first.
https://images-na.ssl-images-amazon.com/...
Here is a link to the firmware download. Find #46 iAudio U2 Firmware V1.68
http://www.cowonglobal.com/zeroboard/zbo...
Score 3
Add a comment
Add your answer
Justin Proshka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 48
All Time: 362
