The Cowon iAudio U2 is a compact device that boasts stylish and elegant looks, an FM radio, line-in and built-in mic recording, and as much as 2GB of memory. It measures just 2.9 by 1 by 0.7 inches and weighs just 1.2 ounces.
3 Questions View all
Will this play through an amplifier with an auxiliary cord?
I want to play music out loud instead of on headphones. Will an aux cord work with this product?
Add a comment
1 Answer
Chosen Solution
Hi,
If you connect a stereo audio cable (aux cord) between your device and the audio in of a powered speaker system it should work.
Depending on your amplifier audio input connections you may need a cable as shown. This is only one example. The 3.5mm plug end will be suitable for the headphone socket of your player the other end depends on the audio input connection type of your amplifier.
If your speaker system is not powered it will too faint to hear properly, if at all.
If it is possible, connect it to a suitable charger as well so as to keep it going for longer, (charging as you're playing - or more realistically, not discharging while you're playing).
Hopefully this is of some help.
Score 3
Add a comment
Add your answer
Kayla Garcia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 88
