Transmission Fluid chane in Epica 2009
How to Change the transmission fluid in Chevrolet epica 2009.
Drop the trans pan remove the oil and change the filter if its so equiped . Put a new gasket and or seal on pan and torque the pan back to about 12ftlb just snug not tight . Fill the trans to whatever you took out of the pan to begin with do not start the car yet your not done . now remove one transmission lines from the radiator or trans cooler . and put a extention hose on the end . Now run the car and watch till clean oil comes out but not to much to drain it , probably about 3-5 quarts or litre depending which unit of messure you use. this gets the old oil out of the torque convertor. Once you have oil out shut off the car dont run it dry.reconnect the trans line , now add oil to the trans and then start your car and move it forward and backward a few times let it run up to normal engine temp and check the level while the car is running. Take it for a drive and then check the oil again . Its important to not have too much oil in the trans as this will make it foam and thats not good so take your time adding oil and make sure you get the proper amount in. Hope this helps
Nasa Mohamed, the attached image shows the drain plug. This plug is used to check and drain the fluid. Add l fluid through the fill cap hole in 0.5 L (0.5 qt) increments until the fluid comes out through the plug hole. Allow the fluid to finish draining out through the plug hole, then install the fluid level plug. No pan on that transaxle.
Pan or no pan you still need to run the old oil out of the torque convertor or you leave more than half the old oil in the trans and only do half the job.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,641
