Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
How can I reinstall OS, as my system won't boot up
Let me explain further...
Suddenly I was unable to boot, just a rotating circle,
I have gone through all the usual holding down of keys, including trying to boot from the CD however always the same rotating circle.
I have even changed the RAM.
So I removed the hard drive connected it to my Macbook Pro. I could see the data on the drive fine as an external drive. However Disk Manager did not like it.
I then ran DiskWarrior and it found an amount of corrections that it wanted to perform which I let run. Now the disk shows all the items correctly About > Storage which it did not originally.
Back in the iMac went the drive, however still no luck booting up.
So my question is - can I just reinstall the OS / or a Boot section like on a PC ?
The MacBook Pro is running El Capitan while my iMac is running Snow Leopard as I recall.
Thanks
Score 1
Add a comment
Chosen Solution
Sadly, it sounds like your HD is going here given the age of the system.
I would get a new drive but you do have a few issues here:
  • You'll need to find a new drive that can run within a SATA I (1.5 Gb/s) system
  • You'll need to stay at best Snow Leopard (10.6) if you have the Core Duo system (A1174) or you could go up to Lion (10.7) if you have a Core 2 Duo system (A1207)
Given the age of the system and its limits do you want to spend the money keeping it going or look at a newer iMac that can run El Capitan so your two systems can run the same software without problem? Remember you can't run newer apps on this older system and Apple is not maintaining these older OS's any more so if you're not careful you could get a surprise one day (malware or trojan). There are a used newer systems out there that might be a better investment.
OK, you're going for it! What to do? First I would recommend going with a SSHD drive so you can get some speed improvement (boot up and running apps). The Seagate Desktop SSHD it offers auto sense SATA speed so it will work with your SATA I system. As a reference if we look at the drives spec sheet: Seagate Desktop SSHD specs note the line SATA Transfer Rates Supported (Gb/s) all three data rates are listed SATA I (1.5 Gb/s), SATA II (3.0 Gb/s), SATA III (6.0 Gb/s). Make sure the drive you do get has SATA I listed if not it won't work reliably.
You'll need to follow this IFIXIT guide: iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement. Makes sure you don't forget to transfer the thermal sensor in Step 22 to your new drive.
Score 2
Add a comment
Most Helpful Answer
Sounds like hard drive is damaged. Not sure if you can reinstall the operating system on top without losing all your data.
Score 2
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 349
