The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
281 Questions View all
slide to unlock is not response (3g 16gb 1st gen)
my phone was drop and the screen was cracked. the wall backgroud is clear. i'm not sure if the digitizer or lcd or front glass damaged, and now the slide to unlock the phone now not working.
Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
is this a 3g or a 1g. either way you can buy the part here and repair it following the guide. just make sure you've got the right model before ordering as the part for 1g isn't compatible with a 3g iphone. details should be on your itunes if you can't see it on the phone (or check your iphone box)
Score 1
Add a comment
Add your answer
jade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 880
