Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 Questions View all
grey screen on mac os 9.1 startup (Gsod)
the first time, my Ibook turns on, but the second time it showed a grey screen on mac os 9.1, should i get a new display or reinstall os? help me
ps: i have a model m2453 and color's blueberry
Score 1
Add a comment
1 Answer
Chosen Solution
Pre-Installed MacOS: 8.6* Maximum MacOS: X 10.3.9
See if it will start up from either a retail 9.1 or the original system installation optical disk, by inserting the disk on start up and holding down the "C" key. If it boots OK, then you know it is a software or hard drive issue. You can then Run Disk Utilities to try to repair or reformat the drive (use the write zero option to map out any bad blocks). Then reinstall a system.
This was the original iBook:
Apple iBook G3/366 SE (Original/Clamshell) Specs
Identifiers: Original/Clamshell - M7716LL/A - PowerBook2,1 - M2453 - N/Aissue.
Score 3
Comments:
thanks mayer! hope that helps
by
Add a comment
Add your answer
Wokipoki will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 420
