A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
Optical drive wont take disc's, no sound when eject button is pressed
So my fan died a few weeks ago i purchased a new one and replaced it, before putting the cover on i plugged it in and ran the ps4 for about an hour to keep an eye on the fan. I then unplugged the ps4 and installed the cover and the got zero response from the system untill i wiggled the power cord and its worked ever since but a few days ago i tried to put a disc in and it wouldnt take it, i pressed the eject button and heard no sound. Ive checked all connections and tried to manually insert a disc with the screw reset the ps4, but that did nothing. I did however notice if the disc is pushed in most of the way it'll eject on reset, so the drive has power. It wont read, accept or make any beeps, any suggestions?
Score 1
Add a comment
1 Answer
Chosen Solution
Most likely the large ribbon cable that goes from the motherboard to the drive board on the disc drive is bad. There's a good chance that the little ears on each side of the ends were torn off or broken when you removed it. This is a very common problem.
The other thing that it may be is the small metal tab that's on the bottom case. If that small metal piece does not make contact with the copper pad on the disc drive board then you won't be able to eject a disc. Since it won't take a disc in that means that there is a problem somewhere else too but you may want to check that metal tab as well.
I hope this helps.
Score 3
5 Comments:
Thank you ill check that out tomorrow
by
Now that you mentioned the ribbon the ear on one side was broken, when i took the cover off today i noticed a metal tab that looks like it would lock the ribbon in, ahould i have lifted that while pulling the ribbon? Also how could i replace the ribbon or fix it?
by
That metal tab needs to be pushed down then the ribbon cable can be pulled out. You should be able to find another ribbon cable on Ebay. If any of those little ears are stuck inside the connector you may need to get it out before the new cable will plug in correctly.
by
I have this same issue, I was told to pull up on the metal tab and pull out the ribbon cable....youtube instructional video....how would one go about getting the broken ear pieces out of there?
by
@nutinbuthehits I sometimes use a small dental pick that I've filed down to fit inside the connector. Even with that they are difficult to remove. I'm sure you know this now but you need to push down on the metal tab...not up.
by
Add a comment
Add your answer
Joseph Dougherty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,259
