Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
917 Questions View all
Battery only holds a bit of a charge
I just recently changed my audio jack/hold button. Upon taking off the battery I accidentally pierced the battery (the only thing around when I pierced it was the audio jack which I replaced anyway). So I ordered a new battery from the site (noticed that it was a slightly lower mAh than the one I have now, but I put it all together and it worked fine.
I received the battery at about 30% so I charged it, it showed it was at full battery. I used it for a few days, went to charge it again, and now it only charges to about 1/5th of battery capacity. It still connects to my computer fine and shows that it is charging. I've tried a bunch of different chargers, I've reset the ipod.
When I put the ipod back together I did notice that the horizontal metal line in the charging port is split in half. The one half is raised up a tiny bit. I'm unsure if I broke something or rearranged something (if this is making any sense at all).
I'm going to use it until it dies and see if it's not holding a charge at all anymore or just capping at a certain percent.
My ipod is the thin version.
Add a comment
1 Answer
Chosen Solution
Modern batteries don't like to be drained completely. However, you can test that and see what happens. My bet is you received a bad battery. Discuss it with iFixit (if you got it from them) via Email. If it turns out to be bad indeed, they'll replace it for you.
Score 2
Comments:
It is now not holding any charge. I will do just that. Thanks!
by
Add a comment
Add your answer
Dylan Curatola will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 130
