Part of the Handycam series of cameras. Manufactured in 2007 by Sony.
3 Questions View all
Why does the door take so much effort to open?
I seem to make a lot of effort opening the side door on my camcorder. I don't want to break it. Is the door supposed to take effort to open, or should I get this looked at?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The problem you are facing is very common for this device. If you have a DVD you must retrieve from the compartment you can pry open the DVD chamber with a spudger. Unfortunately the door may not be able to recover switch actuation with a simple troubleshoot. You may have to replace internal components specifically the the compartment's latch mechanism.
Score 1
Add a comment
Add your answer
Damani Obie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 31
