Released 2015 Model Number: POLSP01W
35 Questions View all
Why won't my Polaroid SNAP print the pictures I am taking?
I have taken a few pictures and all of them printed out without a problem, however none of the photos I have taken recently have printed. I'm pretty sure my camera doesn't have any damage or problems!
Score 12
Comments:
Mine is printing out the paper with no pictures printed on it
by
Student-Contributed Wiki
by
Mine is printing no picture at all
by
Mine is printing out the paper but no picture on it
by
mine wont take a photo the flash goes off then stays on and the paper light blinks at me and i have to hard reset the camara does any one know whats going on
by
Show 2 more comments
Add a comment
Most Helpful Answer
Hi I have the exact same problem too my camera has been safe but why is it not working?? I purchased a few packs of flim and I put in my first one and took a few photos and now I just went to take two pictures and it's not working can you please HELP I'm only new to it''
Score 5
Comments:
my camera doing the same thing, where you able to fix it?
by
Mine is doing the same thing
by
Add a comment
Hi. my Polaroid snap sound like its going to print but at the end it don't print and the three lights start blinking red. How can I fix it?
Score 3
Comments:
Mine is doing this exact same thing and I can't find answers anywhere. Did you get this solved?
by
Add a comment
Hi guys!
Well, I bought mine yesterday and I had the same "problem".
I don't really know why it happens but what I did was:
1. The blue paper should be a bit more "inside" of the camera than the rest of the papers. There's a little hole on the right (where it gets out from then) and when you turn on again the camera the blue paper leaves the camera immediately without doing anything in special.
2. Then you're able to use ur camera.
If you need more help, I would be pleased to share with you my experience
Bye! :D
Score 3
Comments:
hey! I was having the same issue as others have stated: my camera beeps three times and then doesn't take pictures or turn off. I reset my camera so it would turn off, and thenI tried your method- putting the blue paper more "inside" the camera than the rest, and I turned the camera back on, and voila! the blue paper was ejected! I was excited, as I thought the problem was resolved, but sadly, after the paper was ejected, the same thing just happened over and over again. Three beeps, no printing, no turning off. Would you happen to have any other suggestions?
by
same thing is happening to me
by
Mine doesn’t have a blue paper
by
Add a comment
You probably swapped out the paper and could be using the wrong type of paper which would be the reason that the it is not printing.
Score 2
Comments:
Also, please refer to the "Picture Will Not Print" section of the Polaroid SNAP Troubleshooting page if you are having any more difficulty.
by
I didnt put the wrong paper in I put the paper that comes with the camera. But my camera just beeps three times and doesnt take the picture and doesnt do anything
I have a big week this week and I want some pictures
Somebody help me please!
by
Add a comment
I took oy the blue paper and it started working
Score 1
Comments:
I took its out
by
Add a comment
My Polaroid filters won't change. Even when I press different colors! When they are printed out it stays one color everytime no matter how much I move it to a different filter. PLEASE HELP!!!
Score 1
Add a comment
my polariod snap wont print out pictures. nothing is wring with it. i take the picture and then it prints but the paper comes out white and i bought the right paper for it too. PLEASE HELPP!!!!
Score 1
Comments:
Try taking out the SD card. It might help
by
Add a comment
There was a small reset button next to the charger port that you need a PIN to stick into it to reset the camera
Score 1
Add a comment
My Polaroid was working until the third light (sd card) light began to light up constantly. Now it won't print. It takes the photo but no print.
Comments:
i have this same problem - pls someone answer
by
Did either of you get a fix for this? Having the issue on a brand new Snap. No SD card in use, although it should still take a picture and print
by
My SD card light is constantly on as well and when I go to take the photo, nothing is on it. It's blank. It was working fine until then
by
having the same problem
by
Same problem. Help
by
Show 1 more comment
Add a comment
I just received mine as a gift and have yet to be able to take one picture, I can't even get the smart sheet to print.
Comments:
me too. have you gotten it fixed yet? help???
by
by
Add a comment
To everyone who was having this issue - I was until five minutes ago - I just took out the blue paper, even if the instructions tell you to include it.
The camera worked fine!!
Comments:
I took my blue sheet out and now my camera won't print, and the lights won't shut off even though the camera isn't on, and the middle light keeps flashing and beeps whenever I press any of the buttons. This is brand new and I've only used it a few times.
by
the exact same thing is happening to me too!!
by
Add a comment
My daughter just had this problem. It was because the paper was upside down. When you load the paper it goes picture side up. If you are looking at the back of the camera when it prints, you should see the picture, not the writing.
Comments:
Please help I just recently got my Polaroid snap touch and my borders and stickers do not work when I click on the icon to use them it’s blank or instead of having the borders it’s just black boxes. If anyone has had this problem please let me know if you have a way to fix I would greatly appreciate it ! :)
by
Add a comment
Make sure the Zink labelled side of paper is facing down with blank side up
Add a comment
Add your answer
Aaron Hall will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 229
Past 30 Days: 1,307
All Time: 44,452
