Mr. Rice is a stainless steel multi-functional rice cooker and steamer with a capacity for 6 cups of raw rice.
3 Questions View all
Why is my rice overheating and burning?
My device is coming on and working correctly but it is too hot. Sometimes, my rice burns.
Add a comment
Chosen Solution
Your hot plate could be broken if your device is cooking properly, but the heat will not decrease after you take the rice bowl out. In this case, you will need to replace the hot plate springs in order to fix this heating issue.
Mr. Rice SC-887 Troubleshooting
Score 1
Add a comment
Most Helpful Answer
This unit appears to have a thermostat on it. Try turning it down and/or using a thermal IR heat gun to monitor the temperature. IR Thermometer
Replace the thermostat if it has failed.
IR Thermometer Image
IR Thermometer
Score 2
Add a comment
Add your answer
Samantha Schultz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 60
All Time: 883
