Device won't hold a charge, what do I do?
When the charger is plugged into the device the device works fine but when plugged out it dies shortly after.
If the device turns on when the charging cord is plugged in, but immediately shuts off when you disconnect the device. Then, I believe that you may have a faulty battery, since the charging port and cable appear to be working properly. I would recommend looking into replacing your battery.
If you need more assistance I would recommend checking out the DKnight MagicBox II Troubleshooting Guide
I'm having the same issue, and at first glance I can't find an easy way to pop the speaker open. Where are the screws hiding?
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 2,355
1 Comment
Where I can Buy a Battery for a Big Magic Box???
by djelvis20
