HDMI/DVI/VGA does not receive signal
Hi all,
I just built a PC with an i5-4690 and a Radeon R9 graphic card. The VGA is connected to motherboard and DVI/HDMI are with the graphic card.
When hooking everything together, the monitor says no signal (for all inputs) even though the computer turns on fine. I tested the CPU at my friend's place with HDMI and it works normally. I tested the monitor with my laptop through HDMI and it works too.
So basically, CPU, monitor and cables all work; yet when putting together, it's not working. I'm running out of ideas what might have gone wrong. Please help!!
Thanks!
3 Comments
Hi, With the vga do you have to select that in BIOS or can you select the motherboard graphics? Also stupid I know but are there any drivers to be installed for the monitor Do the laptop and the PC have the same OS installed?http://www.asus.com/us/support/Download/...
by jayeff
I will try to hook up the CPU to some other monitor and download the suggested driver. Wouldn't monitors nowadays can be automatically detected though? Since I can't see anything on my monitor right now, can't really change anything on the settings :(
by Hamishim
Hi, I was thinking that the drivers might contain .inf files that set the various resolutions that your monitor can handle, and therefore might give some adj,. parameters.
by jayeff
