Can I use charger of other ASUS laptop with my own ASUS
My ASUS is X550LB. Its adapter has the ff. specs:
INPUT: 100-240V ~ 50-60Hz, 1.5A
OUTPUT: +19V, 3.42A
Since mine was broken, I want to borrow the adapter of my brother's ASUS K56CB laptop with specs of:
INPUT: 100-240V ~ 50-60Hz, 2.0A
OUTPUT: +19V, 3.42A
Is it okay? It seems that their only difference is the input ampere. I'm not quite sure. Need help. Thanks!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi,
As long as the adapter's output connector fits into your PC power socket properly, there should be no problem as both adapters are supplying the same output voltage and current.
Score 2
Add a comment
Add your answer
Angel Gacutan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 260
