The Microsoft Surface 2 was manufactured by Microsoft Corporation and is the second generation of Microsoft tablets. It was launched on October 22, 2013 and includes features such as upgraded processing power and screen resolution.
29 Questions View all
What to do when the battery is draining too quickly?
The battery in the Microsoft Surface 2 is draining too fast. The battery expectancy is said to be 10 hours when fully charged but dies much quicker. What to do in order to prevent the the battery from draining so quickly and how to maximize the efficiency of its life span.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Battery estimates vary widely depending on what you are actually doing. 10 hours is probably not "normal use" but some utopian fantasy.
If you want to make your battery last longer, turn of unnecessary services like Bluetooth, wireless, close applications which update regularly (like Mail) and close any applications or web browser tabs that you're not actively using.
Batteries also degrade over time, so it also matters how old is your device?
Score 1
Add a comment
First, make sure your device has the latest updates.
If your battery life is shorter than expected, check to see that all unused applications are not running in the background. While not using your device, make sure that you use a minimal amount of the battery off by putting it into sleep mode.
Score 1
Add a comment
Add your answer
oluchianya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 63
