Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
167 Questions View all
My screen only works at certain angles
How can this be repaired
Add a comment
Chosen Solution
Do you see a faint image on the screen when the display is out? You might want to use a flashlight from behind the screen, and see if you can see anything on the screen when the display is dark. If you can, this most likely means the inverter cable is being crimped and needs to be replaced or at least re-positioned. If you can't, and there is absolutely nothing on the screen when it's dark, then it's likely the display cable and I'd follow Mayer's instructions. Also, make sure the cable is firmly seated on both ends...sometimes it will simply be loose, and the motion of closing the case causes it to disconnect. But more often than not in your situation, it's the inverter cable, and you'll see a faint image on the screen.
Score 4
Comments:
+ good
by
Add a comment
Here is a list of the PowerBooks that carried the 4.3: http://www.everymac.com/ultimate-mac-loo...
Most likely you will need to replace the Display Data Cable. For the correct directions and part we will need to know the EXACT machine you have.
This is the part you will need. It works in all G3 iBooks:
iBook G3 12" Display Data Cable
The installation instructions link will be with the part under "More information".
Score 3
Comments:
Add a comment
Add your answer
Tom Anderson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 638
