Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Question Closed
battery life...help me please
hi,
I charge my iPhone 5 to 100%
in 7 hours of standby its drain to 17%
new battery replace
airplan mode
all instructions to save battery
low power mode
all of this didn't help to save battery on standby
3 Comments
okay there is to thing
Ic u2 and ic power management
the wrong with ic u2 or ic power
by
From what you said. I would say the U2 IC. When you use a aftermarket charging cable or one of those charging cables you get from a 99 cent store, it damages the U2 IC chip. thus making it unable to hold charge and letting the battery life drain fast.
by
thnx for info
by
Add a comment
1 Answer
Chosen Solution
FIrst let the battery drain it self to 0. then Try changing the battery and changing to a original charging cable. charge the phone to max and see if it works.... if still dont work.
I think there is something wrong with the U2 IC chip on your logic board. You might need to get the U2 IC replaced.
For this repair you need the right soldering tool and requires a good understanding of micro soldering. Take it to a professional if you dont know how.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
