Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1077 Questions View all
Use iPhone 6 plus battery to test damage?
I was mistakenly told a phone I was diagnosing for water damage was an Iphone 6 plus. turns out to be a 6S when client drops it off.
I only have the batteyr I ordered for a 6 plus. The connector seems the same. Is it ok to use this battery to test the repair while I wait for the proper battery to arrive?
Thanks a lot
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Have you thoroughly cleaned the water damaged parts on the phone such as the flex cable connectors, any corroded areas on the mainboard?
If yes then you can try another battery to test and see if it works. If the battery can connect in then it doesn't hurt to try.
Score 1
Add a comment
Add your answer
rcast will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 143
