Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2688 Questions View all
Question Closed
Use iPhone 6 plus battery to test damage?
I was mistakenly told a phone I was diagnosing for water damage was an Iphone 6 plus. turns out to be a 6S when client drops it off.
I only have the batteyr I ordered for a 6 plus. The connector seems the same. Is it ok to use this battery to test the repair while I wait for the proper battery to arrive?
Thanks a lot
Add a comment
1 Answer
Chosen Solution
Have you thoroughly cleaned the water damaged parts on the phone such as the flex cable connectors, any corroded areas on the mainboard?
If yes then you can try another battery to test and see if it works. If the battery can connect in then it doesn't hurt to try.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 171
